slot-plate.stl
Plate that affords adjustable column stagger and splay via slots for M3 bolts.
Standard Tesselated Geometry -
1.89 MB -
06/27/2022 at 23:14
Download
thumb-cluster.stl
Thumb cluster switch housing
438.85 kB -
06/27/2022 at 23:14
Download
finger-column-single.stl
Keywell for a single finger column of switches
591.20 kB -
06/27/2022 at 23:14
Download
post-hex-m3-25mm.stl
Post providing adjustable height for 25mm
11.21 kB -
06/27/2022 at 23:14
Download
finger-column-double.stl
Keywell for a double column of switches (index finger or pinky typically)
178.21 kB -
06/27/2022 at 23:14
Download
post-ring-29mm.stl
29mm post for pinky finger
11.21 kB -
06/27/2022 at 23:14
Download
post-pinky-42mm.stl
42mm post for pinky finger
11.21 kB -
06/27/2022 at 23:14
Download
brain-box-v2.stl
Case for Elite-C MCU, RJ9 jack, and reset button plus slack wiring
326.74 kB -
06/27/2022 at 23:14
Download
m3-washer.stl
Washers for bolted connections
17.07 kB -
06/27/2022 at 23:14
Download
case-v2.stl
328.60 kB -
06/27/2022 at 23:14
Download
post-thumb.stl
Post to mount the thumb cluster to the slot plate
102.82 kB -
06/27/2022 at 23:14
Download
bottom-box.stl
Box for under the slot plate
331.92 kB -
06/27/2022 at 23:14
Download
lid-v2.stl
293.25 kB -
06/27/2022 at 23:14
Download
elite-c-case.stl
Housing for the Elite-C microcontroller
9.85 kB -
06/27/2022 at 23:14
Download
