microCmd
MicroCmd is a small battery-operated pocket device.
This is the first time I used ARM LM3S5632 chip in my construction - there's nothing to be afraid of as I figured out:)
Hardware:
Nokia 3310 LCD
3 axis I2C accelerometer
microSD slot
mini USB connector
battery charger circuit
PlayStation Portable 2 axis analog "joystick"
IR LED diode to rule all IR devices at home :)
.. and.. that's it! :)
All that was squeezed to small area 59×38mm. The 2 layer boards will be maufactured by Pool Service in fab house in my country.
Martin Hub wrote 05/14/2017 at 16:45 • point
Thank you @jaromir.sukuba
I had to look because it's an old project. I've added short wires to the joystick so it's not completely flat/parallel to PCB but its ok. The wires are also holding the joystick in place.
jaromir.sukuba wrote 05/14/2017 at 12:58 • point
Lovely project. From pictures I can't see how is the joystick attached to PCB. Glued and soldered with short jumpers, or perhaps reflowed directly on PCB?
