The CNC router work on this box was quite a bit harder than the Moria box. The eclipse was especially tricky because the design is routed from both the front and the back at various stages and if the alignment is off even a little bit then it looks terrible.
The Raven design in the middle was finished with a .8 mm router bit, after removing most of the material with 1.6 mm and 3.175 mm bits. Then I filled it with clear epoxy that had copper-colored mica flakes stirred in.
Koen van Vliet
Magnus Selin
Martijn
agp.cooper
