Materials and tools used in this project:
- Oak sliced veneer 4.5mm, 2,5 mm
- Alder sliced veneer 4.5 mm
- Walnut sliced veneer 4.5mm, 2,5 mm
- Plywood 4 mm, 6 mm
- Bearings: d=4, D=9, H=4 x 8 pcs
- Bearings: d=8, D=14, H=4 x 10 pcs
- Screws: 2.5x12 mm, 2x10 mm, 2x4 mm.
- Glass bottles: D=47, H=80, V=90 ml - Small metal brush
- Bamboo sticks D=4mm (for BBQ)
- Magnets D=3mm, H=4mm (NdFeB) - Masking tape
- Glue: Titebond 2, 3M Scotch-Weld Fastbond 30, CA Glue + Activator
- Wood tinting: Vidaron Beica Walnut (B09), Palisander (B10), Mahon (B13)
- Oil: Tundra oil with Carnauba Wax
- Bee Wax
- DIY Laser cutter/engraver 520x520mm, 5.5w
- Disk sander - Screwdriver
- Hand router 1600 W, V-bit 45 degree, Round bit R=5 mm
- Sandpaper 120, 220, 320 - Clamps
Timber Rough
agp.cooper
szynyszyl
