1Install CircuitPython to pico
Prepare CircuitPython according to this instalation.
https://learn.adafruit.com/welcome-to-circuitpython -
2Design and make enclosure
Design the enclosure to match toggle switches to be used.
My 3D printer doesn't have enough work area to output at once, so I designed it to be able to print out separate pieces and glue them together.
3Soldering Time!
Install toggle switches and pico, solder as shown in this schematic.
It is not important which pins are wired, as it can be easily modified in the firmware.
4Copy code.py to pico
code.py is here.
https://gist.github.com/hsgw/db5753c29c71fa35bb79a933cf316e77The "adafruit_deboucer", "adafruit_ticks" and "adafruit_hid" libraries are required.
Debugging code can be used to verify that all switches are working well on your serial monitor.
hsgw ➿
