Here how it works in a nutshell
And below is a pinout for my specific implementation
ESP8266 self hosted WIFI-to-UART bridge
After using terminal monitor for a while I've decided to review feature list, or more specifically get rid of the stuff I don't use. And add screen instead.
It is not a big screen, only 8x21 symbols with tiny font, however now tool can be used completely offline. At least to see serial output from target device, you don't need web app.
This is how it looks like in practice
Make sure that all parts came in good shape and no apparent damage is done on the way. Flash Terminal software to Wemos D1 board just to make sure it works.
Solder headers to the Wemos D1 module. Long part of the header should be directed to the motherboard. Make sure to align them right, use motherboard as an aligning tool. When soldered it will be tightly pressed against battery socket.
Start with just one pin each side and double check your work. Then you can proceed to other pins.
Solder headers to the motherboard from the back side.
Hi Vincèn
AFAIK it depends. It will definitely wont handle +/-15V voltage levels, You'd need voltage conversion first. Please check what is actual voltage levels that you have. In many cases (read modern devices), level is 3.3V or 5V. In that case it should work.
Hi
Is it possible to use that device to control by RS-232 some devices ? Does it output some standard RS-232 levels ? I would use it with ESPHome and Home Assistant to control some devices through UART ;)
Thanks
Vincèn
