The Hamster Wheel Tracker is a simple fitness monitoring device for your hamster. The speed and distance traveled by the hamster in the wheel are measured using two opposing neodymium magnets with complementary poles, which run past the device's bipolar Hall sensor switch. The recorded values are displayed on an OLED. The button is used to reset the stored values for the maximum speed reached and the maximum distance traveled in a day. The total distance covered since the device was started up is retained. The corresponding values are stored in the EEPROM so that they are not lost after a power supply interruption.
The Hamster Wheel Tracker is a straightforward fitness monitoring device designed specifically for hamsters. It utilizes two opposing neodymium magnets with complementary poles, which pass by a bipolar Hall sensor switch to measure the hamster’s speed and distance traveled. These measurements are then displayed on an OLED screen.
You can reset the maximum speed and maximum distance values for the day using the button on the device. The total distance covered since the device was first turned on is continuously tracked. Additionally, all data is stored in the EEPROM to ensure it isn't lost during power interruptions.
For more information, visit Hamster.
