Hackaday.io Hackaday.io
Sign up Log in
MIDI Controlled Drum Set
Programable drum set using a teensy 4.1 controlled through MIDI
owenowen
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
516
1
3
2
Team (1)
  • owenowen
Join this project's team
  • Facebook
  • Twitter
  • Website
ongoing project
midi teensy drums MUSIC pneumatics
Related lists
Musichacks
Musical Instruments (and related) DIY/open projects
This project was created on 07/08/2022 and last updated 4 years ago.
Description
This project uses a teensy 4.1 to process MIDI signals, and depending on the note, drive a corresponding pneumatic cylinder. it uses this library: https://www.pjrc.com/teensy/td_libs_MIDI.html. The circuitry is also from the link
Demonstration: https://www.youtube.com/shorts/2mMADUwqW0w
Project Logs
Collapse
  • Circuit board update
    owen • 08/16/2022 at 01:39 • 0 comments
  • PCB design
    owen • 07/22/2022 at 07:03 • 0 comments
    started laying out some PCBs to control servos and relays, among other outputs
  • PCB design
    owen • 07/22/2022 at 07:02 • 0 comments
  • Moved to Soldered breadboard
    owen • 07/10/2022 at 01:09 • 0 comments
    Moved parts to a soldered protoboard, still some issues with the wiring.
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Brad Purkey wrote 10/12/2023 at 21:26 • point
Awesome! Did something similar with a pneumatic driven drumset called the Drum Robot back in 1999 for the opening of Experience Music Project (now MoPOP). Ours was driven by a computer talking to a custom PAVO midi interface which then actuated pneumatic valves to hit the drums. It was tied in with a touchscreen based interactive exhibit that taught you how to play a drum beat, step by step.
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MIDI Controlled Drum Set", please tell us the reason.
Send message
Remove Member
