This solution would work (with a faster CPU) but the Zynq7010 Cortex A9 CPU isn't able to send a new word (32 bits phase shift) every 1 or 2 milliseconds with enough timing precision. I'm now trrying to implement an all PL solution. See next log.
The AD9851_0 VHDL IP is controlled by a GPIO IP (axi_gpio_AD9851) where the two 32 bits output ports act as:
- Port 0: 32 bits DDS phase increment to the AD9851 according to the formula:
Out frequency = phase_increment * 180 MHz / 2^32
- Port 1:
- bits 31 ... 17 : not used
- bit 16 : valid_in signal to the AD9851_0 IP
- bits 15 ... 8 : pwm duty cycle (0 - 255) to AM modulate the output
- bits 7 ... 3 : output phase (always 0)
- bits 2 : power down (0=power out 1=power down)
- bit 1 : always 0
- bit 0 : AD9851 6x (ask the AD9851 to multiply by 6 the 30MHz reference to obtain a 180 MHz clock reference)
