Rev2 will feature a 0.5mm circular steel gold-plated pin, to connect to the breadboard contacts. (0.5mm is the standard size of a resistor or capacitor leg.) We completely redesign the molded strain relief for the needle heads. The new design is minimalist and discreet. The molded strain relief is going to be made from TPE (a soft elastic material).
The wire is going to be 1 meter long and the insulation material will be soft silicone. The wire gauge will be 24AWG with 40 copper strands.
We are also going to use gold-plated stackable banana plugs with a low contact resistance.
Pitron
Ryan Walmsley
Quinn
Paul Kocyla
$14 is for a pair or for one lead?
