NTS-1 as a portable effet processor
07/19/2022 at 06:46 • 0 comments![]()
The NTS-1 is not only a good synth, but also a very capable effect processor, and having a built-in battery makes it the perfect companion of your pocket operators!
Just grab an audio cable to connect the two, and it's perfect for a quick jam on the dinner table, like I did here! 🙂 -
Update about the NTS-1 USB vs battery USB
07/18/2022 at 12:12 • 0 commentsI received a comment on Reddit asking if it was possible to rewire the battery input to the USB of the NTS-1.
Well, I initially looked into doing that, but since the battery output is already connected to the NTS-1 USB power line, it would create a loop. I'm afraid it would require a different battery management system to do that (some battery management systems use the same lines for input or output).
I may be possible by designing a custom PCB to to break the loop and allow the current only in one direction (either charging the battery, or powering up) but that's beyond my current skills. If anyone has ideas on how to achieve that, let me know :)
Yohan Lasorsa
