# download mps compilers
brew tap tgtakaoka/mspgcc
# prepare folders
sudo mkdir /opt/homebrew/lib/msp430 /opt/homebrew/lib/msp430/lib /opt/homebrew/include/msp430 /opt/homebrew/include/msp430/include
sudo chown -R $(whoami) /opt/homebrew/lib/msp430 /opt/homebrew/lib/msp430/lib /opt/homebrew/include/msp430 /opt/homebrew/include/msp430/include
# run install
brew install libc-msp430 gdb-msp430
https://exfil.co/2016/02/11/goodfet-on-os-x/
Found a good starting point to talk with the MSP430, but sadly it runs into a weird bootloader password issue.
goodfet.bsl -P ./goodfet.hex --fromweb Use -h for help Use --fromweb to upgrade a GoodFET. MSP430 Bootstrap Loader Version: 1.39-goodfet-8 Invoking BSL... Transmit password ... Use -h for help Use --fromweb to upgrade a GoodFET. MSP430 Bootstrap Loader Version: 1.39-goodfet-8 Invoking BSL... Transmit password ... Traceback (most recent call last): File "/usr/local/bin/goodfet.bsl", line 1987, in main(0); File "/usr/local/bin/goodfet.bsl", line 1887, in main bsl.actionStartBSL() File "/usr/local/bin/goodfet.bsl", line 1166, in actionStartBSL self.txPasswd(self.passwd) #transmit password File "/usr/local/bin/goodfet.bsl", line 1136, in txPasswd wait=wait) #if wait is 1, try to sync forever File "/usr/local/bin/goodfet.bsl", line 801, in bslTxRx rxFrame = self.comTxRx(cmd, dataOut, len(dataOut)) #Send frame File "/usr/local/bin/goodfet.bsl", line 480, in comTxRx rxHeader, rxNum = self.comRxHeader() #receive header File "/usr/local/bin/goodfet.bsl", line 386, in comRxHeader if not hdr: raise BSLException("Timeout") __main__.BSLException: Timeout
aha! So the tutorial uses a capital P where the flag should be a small p. Or not, maybe the password stuff is set somewhere else or while compiling. writing the ./prebuilt firmware worked.
board=goodfet42 goodfet.bsl -p goodfet.hex
Well that wasn't really a solution, but somehow I got it to except the firmware, probably by using the "fromweb" flag for it, where it wasn't confused by all that.
I think I forgot to finish what made it work in the end and now two years later I'm wondering myself
Interesting decision, but it surely needs to be improved
which decision do you mean exactly?
