Most animals can't afford a bathroom fixture with independent fan & light switches so some kind of remote control is desired.
There are no GU24 wifi bulbs. There is a 100W wifi A21 bulb
https://www.amazon.com/Connected-Bluetooth-Smart-Tunable-Changing/dp/B08978J94N/
Lions have gotten by with a GU24 to A21 adapter, but this doesn't give the most light. The ideal solution would be a COB light
https://www.amazon.com/White-Engine-Integrated-Driver-floodlight/dp/B07PB23N6L/
https://www.amazon.com/dp/B08L4NDY9B
This would entail stuffing a triac, buck converter, simple radio chip, & GU24 adapter in the enclosure. The mane problem is cooling the COB light. There could be a fan heatsink. The lion kingdom doesn't believe IR would work near such a bright lightbulb.
