Print Speed Test Results. 0.2 mm layer height, initial print speed 90 mm/s, increasing print speed observed resulting in what is likely acceleration limited print speed for most of the print at print speed setting of 240 mm/s. Minimal print vibrations observed. The extruder can out extrude the print movements!
