MSX1 and MSX2+ together...
10/14/2023 at 22:43 • 0 commentsWhen I was assembling all the PCBs for my MSX2+ project, I used all the compatible PCBs that were available in the MSX1. And since there were still the VDP 9918, the Beer IDE and the 64KB Ram from MSX1 project, why not build another one?
To do this, it was necessary to assemble a new Clock, CPU, PPI, Clock and PSG.... PCBWAY minimum order is 5 pieces, so I still have some spare parts :)...
Above MSX2+... Below (and connected to monitor) MSX1
Baffa-X (MSX) using Wifi Modem
04/09/2023 at 22:26 • 0 commentsBaffa-X (Baffa-2 with MSX Boards) now has a Wifi Modem based on 16550 and Esp32. It's similar to original Baffa-2 SIO Board and compatible to BadCat Card software/terminal.
Aleste Music using FM-PAK + PSG on Baffa-X
04/07/2023 at 19:53 • 0 comments -
It's Alive - Baffa-X2 (MSX-2+)
04/06/2023 at 00:28 • 0 commentsFinally, I could test all the boards together. Now, it's possible to upgrade the Baffa-X from MSX1 to MSX2+. It replaces the VDP v9958 (compatible with other Baffa-2 projects), Memory of 64KB by 1MB Ram Board (megaram) and adds Rom/SlotExpansion and RTC Boards.
Finally an original V9958! 8th order!
04/05/2023 at 21:16 • 4 commentsAs we know, the V9958 package has no notch (hole). All fake V9958 have the same code 2703 2122 IACC, and we can notice the painting of the label that is different. (the last one at bellow is the original IC)
Another V9958 Fake (this time) received from UTSource
04/04/2023 at 18:07 • 0 comments![]()
Baffa-X (Baffa-2 MSX1) at MSXRio Mar-23
04/04/2023 at 18:05 • 0 comments![]()
Lots and Lots and Lots of Fake v9958
03/25/2023 at 23:41 • 1 commentHi folks,
bad news. The retro market is flooded by rebranded v9958 fake chips. I bought six already from different Aliexpress stores and all came with the same serial and "notch". As we know, the package of yamaha v9958 has no notch. (Example on figure bellow)
For while, I tried those six I received from Aliexpress stores. All have the same code and manufacturing date:
It seems that the are rebranding "toshiba" 64 pin ics like 68000 or 1253. Compare for yourself....
Unfortunately, this is leading to a price dispute and ruining the MSX2+ spare parts market. And this project is stopped waiting for a part that works.
My first v9958 was about 10 usd on august, 2022. ... Today (march, 2023) I got a quote of 111 usd from utsource.
MSX2 Setup coming soon
02/23/2023 at 12:05 • 0 commentsThe new MSX2 setup is coming soon.
1MByte Memory Mapper on Baffa-X
02/22/2023 at 03:09 • 0 comments1MByte Memory Mapper working correctly. This board is part of the new set of boards to transform the Baffa-2 MSX1 into an MSX2(+) compatible computer.
![undefined]()
I'm waiting for the missing components to arrive to finish the other boards. News coming soon.
Augusto Baffa
