1Create an image file
Draw any image with a resolution of 160x120px and call it "Image.png"
2Run the C# console app
Place the Image.png in the same folder of the C# console app (Note that I've built that using .NET 4.8), it should create a text file called "Array.txt", the file should contain a 2D array for the Arduino.
3Hook up the Arduino and upload the code with your image.
Once you have the text file, replace the array of the program with your image's array.
Geri
