Notes:
- definitely order 0.8mm boards (I failed because it was after midnight... )
- pins for display can be shortened by shield -> edit footprint!
- 5V stuff is confusing! I only considered it for getting more "bang" for the buck
- next version should have Attiny13 for I2C RGB control
- maybe add an ESP12 foot print
- play with MQTT (red alert / temperature stuff)
- also RGB pinout is not correct!
- resistors for colors are not in the same order and values must be corrected
- ESP12 analogWrite has 10bit resolution!
Nice!
It's pretty bad when your buck converters give you bang.
yeah, but when you forget that for 3V3 you have to connect some pads first to make it work ... then I really don't see the point in it at all. If some people still uses 5V boards than they should buy some cheap converters on eBay or something :)
That backlighting is pretty slick. Did you use regular smt LEDs or did they have to be right-angle?
regular 0603 / 0606 smd rgb leds, I think they mostly reflect on the metal case, they shoot straight up into the plastic, but it looks even better in real life :)
