In a previous log, I mentioned that I have revised the original design of the Bell & Howell digital multimeter based Digital Dice Tower. I presented some of the features in that log and provided a video of how it works. Now, I am starting a new series of logs that step you through the build in significant detail. I'll be posting these logs over the next few weeks.
- Acquiring the Parts, bill of materials (BOM)
- Prep the Case and Board, steps to prepare the case and PCB
- Build the Controller (Part 1), Solder the dip sockets, power bus, and audio circuit on the controller board
- Build the Controller (Part 2), Solder the connections to the nixie display drivers and lamp transistors/drivers
- Build the Controller (Part 3), Connect and install the rotary encoders, button, LED, and speaker
- Mechanical Assembly, Apply graphics, install the controller, mount speaker, LED, and controls
- Software and ICs, options to program the ATmega 328P and a walk through the software
- It's Alive!!!, demonstration of the new digital dice tower
