To prove the software some basic hardware is required. The attached schematic will be implemented on strip board which can be attached to the dev board. The main features include...
- Pin assignment from the microcontroller
- Input voltage measurement
- Output voltage measurement
- A current shunt measured by a second voltage
- A high side switch when operating in buck mode
- A low side switch to operate in boost mode
There is also protection zener diodes for development.
