1See Project Log
Since this is built from whatever scrap I had lying around or could find at the dump, it's difficult to give reproducible instructions. If you want to build your simulator out of whatever parts are available, you will likely have to improvise a bit more. This project is also made up of different parts that can be completed separately. For example, maybe you want rudder pedals but nothing else. Because of the nature of this project, I decided to put construction information in the project log.
