9. LoRaWAN´s Test with Multiple Sensors
A project log for Environmental Toolkit for an Ecological Area
LoRaWAN IoT system with the Arduino MKR WAN 1300, that help my community to monitor the air quality and water of our ecological area
guillermo-perez-guillenGuillermo Perez Guillen 07/26/2022 at 20:410 Comments
LORAWAN´S SIMPLE TEST
Before doing the field test, I decided to do a basic test indoor in order to correct any hardware or software issues. In the figure below I show you the devices assembled and ready for the basic test.
In the video below I show you the test inside my house and the three sensors work without problems and the receiver device receives the data.
LORAWAN´S FIELD TEST
This is the place I chose to test my LoRa devices.
In the image below I show you the transmitter and the receiver ready to work.
Finally, in the video below I show you the tests carried out with this system.
Notes:
Rich text editor
