Macro samples are usually to large to view on a slide or dish, which means you have to attach them to another object and then lower them into the focal space. The average size of samples that I will be viewing are around .3 to 3mm in size so I decided to design a magnetic sample holder that can be changed easily when changing samples . The sample will be attached to this with a small application of superglue, the amount of super glue necessary for this is smaller than the tip of a needle. The design on the right will be glued into place and the design on the left will be removable creating a magnetic hold. All of these parts are being printed on a resin printer to get the accuracy on the tip.
The magnets I will be using are 1*2mm
Solid view of the stack
X-ray view to show how the magnets will be aligned up.
The tips height was important to bring the sample into a position that would maximize light exposure. I was able to simulate this in Tinkercad.
Now I just need to get it all printed and the magnets should be here in a few days.
Zachary Marlow
