First video presentation
12/11/2016 at 02:57 • 1 commentI finally managed to upload a video in which I talk a little bit about what an RTOS is and then I step through the code to show you the big building blocks.
I will try to upload some technical presentations as well soon.
Here is the youtube link :
Stack layout (revisited)
12/03/2016 at 15:45 • 0 comments -
CALL and RET
12/03/2016 at 07:24 • 0 commentsA few people asked me why I defined these two macros in the assembly source file.
There is nothing wrong with "bl subroutine" or "bx lr" but these two macros help me read the code faster when I look for specific subroutines.
I call it "professional defect" since most of the days I stare at Intel assembly and I am used to mentally separate code blocks in a specific way.
Task Stack
12/03/2016 at 06:44 • 0 commentsHere is how a task's stack looks like when the scheduler activates :
First part (top 8 registers in the diagram) is automatically saved by the interrupt handler, the remaining 8 registers are saved by the following code :stmia r1!,{r4-r7} // store r4-r7 and increment r1 for each one mov r2,r8 // r2, r3, r4 and r5 are already saved mov r3,r9 // so we can use them as intermediary regs mov r4,r10 mov r5,r11 stmia r1!,{r2-r5} // registers are in order on stack r4...r11
Rock-solid functionality
12/03/2016 at 05:53 • 0 commentsI used to get random faults from time to time and these things are quite hard to debug. After a lot of hours I managed to finally isolated the issue in the mutex handling system.
I redesigned the system, it's much more robust now and it didn't fail yet like the old system.
Good part: I have 32 max mutexes now since I store them as bits into a word
Bad part: I had to remove the string from the code :) It's now 1024 bytes without any string.
I will try to optimize some more size-wise so I can put back the string at least partially.
On another note, some more docs are coming, stay tuned !
Better sleep
12/02/2016 at 03:58 • 2 commentsI replaced the infinite loop in the idle task with "wfi" instruction. Theoretically this should put the processor to sleep until the next systick interrupt and this will save energy. I said theoretically because it needs some setup but it seems to work out of the box so I will keep it as an option.
I also uploaded the RAM memory map.
Documentation
12/01/2016 at 06:35 • 0 commentsAll sources are fully commented but proper video documentation will follow in the next couple of days.
If there is enough interest I might even make a step-by-step building videos.
Stay tuned
