DIY Macro Keyboard
6 switch 2 rotary encoder macro keyboard using arduino
I developed this macro keyboard to use it with Fusion360 since some of the shortcuts are quite clunky and having this allows me to work way faster. It takes some time to get used to it but once you get the hang of it it speeds up developement drastically.
Of course since it is Arduino based you can reprogram it to do whatever you want, even program different profiles for different use cases.
Macro.ino
Code I use to control Fusion360
ino - 4.17 kB - 08/07/2022 at 11:40
Download
Macro.f3d
3D files for the macro keyboard
fusion - 573.95 kB - 08/07/2022 at 10:59
Download
View all 7 components
  • 1
    Print 3D parts
    Print the provided 3D files
  • 2
    Insert switches and encoders
    Tolerances are tight enough so that they can all be friction fitted
  • 3
    Wire parts
    Wire the grounds of the encoders together with the copper wire (make sure to heat the ends of the cable to remove the enamel)  and wire it with one pin of the switches so they all have a common ground.
    Solder the 5V pins of the encoders together.
    Solder a loose cable to all of the remaining pins of the switches and the encoders (colored cables).
View all 9 instructions
