Features
- Raspberry Pi Pico
- Automatic overclocking of processor
- VGA uses the 2nd core, main program uses 1st core
- VGA
- 8-bit output in R:G:B 3:3:2 format (256 colors)
- VGA progressive output up to 1280x960 resolution
- Automatic configuration video mode timings
- Composite sync
- Video formats
- 1 base layer and 3 overlay layers with transparency
- 30 frame buffer formats: graphics, tiles, text, special
- Colour palettes
- Screen split into segments of different formats
- RLE compression
- Transparency with selectable key colour
- Hardware sprites
- Output layers to different color bits (color planes)
- PWM mono audio output
- 3.5mm stereo jack
- Joystick connector(s)
- JOYPAD or
- 9-pin "Atari" Joystick
- 99.5x69.5mm card
- Fits into 100x76x35mm extruded aluminum enclosure
- (4) 4-40 mounting holes
Software in GitHub
- ProgramNameJP = JOYPAD version of the programs
- JOYPAD has 3 more buttons than the JoyStick
- ProgramNameJS = Atari JoyStick version of the programs
- Non JoyStick and non-JOYPAD version of the programs
land-boards.com
Nick Bild
Bikash Narayan Panda
Jenny List
James Fossey
