1Get source code
Get the working code from https://create.arduino.cc/projecthub/thesahilsaluja/cpu-and-ram-usage-monitor-windows-linux-921282?ref=search&ref_id=i2c%20lcd&offset=43
and do necessary modification in the code. The working code for BW16 can be found under Files.
2Connecting between BW16 Type C and I2C 16x2 LCD
3Final result
Upon uploading the code to BW16-TypeC, the data can be displayed on the LCD screen.
