Evac rail
an evacuation rail way that is used for fast exit when instant flood occurs around residential areas for people who have limited locomotive
Public Chat
This project is about building an evacuation rail way that is used for fast exit when instant flood occurs around residential areas for people who have limited locomotive capacity without the need of getting out of their homes.
What do you imagine the future? I say whatever we hoped and do now!
This project is about building an evacuation rail way that is used for fast exit when instant flood occurs around residential areas for people who have limited locomotive capacity without the need of getting out of their homes. This is done by using the residential homes and building foundation as a support structure to construct small railways from one home to the next which pass through each homes so that by the emergency time each home residence are rescued using the rail way which pass through the roof of their homes.
To provide additional function of the system other than emergency use, it is also used for transportation of trash/ home waste saving fuel consumption of garbage collector vehicles which will reduce carbon footprint of trash collection, distribution of delivery if the system is automated and many other applications one can imagine.
The main target of the project is cost saving in construction of the railway system while providing a mechanism that make Climate Resilient Communities.
I made the draft design and proposed the project to a construction company and I have been asked to do the full design in detail so that the company make a model test in a residential compound.
View all 2 project logs
