The specifications
| Elite | Professional | |
| Calibrating time | 4-5 m | 4-5 m |
| Sensor reading frequency | up to 400 Hz | up to 800 Hz |
| Host computer update rate by Wi-Fi | 30 fps | 60 fps |
| Host computer update rate by wire | 60 fps | 120 fps |
| Battery capacity | 500 mA/h | 800 mA/h |
| Battery life time | 5 h | 8 h |
| Battery life time in idle | 48 h | 48 h |
| Battery charge time | 40 m | 1 h |
How I did it
The task was to design and prototype hand tracking gloves. The product should be low cost, easy to produce, with precise, high-speed tracking. The gloves should be comfortable to wear and easy to put on and remove. I built four prototypes with different types of IMU sensors and with different numbers of sensors in different positions on the hand.
All prototypes shared the same control circuit, which includes:
- Power management and battery charger
- ESP32 microcontroller
- USB <-> Serial interface
My task list for this project included:
- R&D Research all existing products and choose best possible design
- Design the schematic and PCB for microcontroller and sensors with Siemens Xpedition
- Design the plastic housing with Siemens NX
- Create the firmware with C++
- Create the host software and Unity 3D integration
The firmware contains a UDP server, and various filters: Kalman, Mahony, Madgwick. The main calibrating algorithms are implemented on the host side. The table below contains the sensors used in the prototypes. All of them have approximately the same result, and there are no winners.
The sensors used in prototypes
| Manufacturer | Part ID |
| BOSH | BMX055 |
| ST | LSM9DS1 |
| TDK | ICM-20948 |
| BOSH | BMX160 |
The prototypes used the same battery 800 mA/h, but the testing showed it was too large. There is an opportunity to create a reduced version of the product with a smaller battery.
This was a very interesting project, and I am grateful to the company who requested this work.
h2w
dekuNukem
tlankford01
Andrew Mitz
Looks great, any chance you could release the source?
