Adaptive wireless switch
Adaptive switches are often used by people with limited hand function. This switch looks like a game controller and uses a low cost keyfob.
This device was developed for a person with intellectual and physical disabilities who needed an exceptionally easy way to select and play videos. This is the remote control. The Raspberry Pi-based video jukebox "PlayVideo" is a separate project (see my project list).
The PlayVideo player can be operated with a wired switch or a SimpleRF keyfob sold by Adafruit Industries. But, a keyfob requires good hand and finger control. The Adaptive Wireless Switch moves the keyfob circuit into an more manageable form factor, essentially a game controller that has two buttons. The adaptive switch has a LiPo battery for long operation and a built-in charger. The case is made by 3D plastic printing. The circuitry is composed of 3 Adafruit circuit boards, 3 switches and a LiPo battery.
1 Controller body top v8 (final).stl
Final 3D print file for controller body, top component.
Standard Tesselated Geometry - 2.10 MB - 08/01/2020 at 12:35
Download
2 Controller body bottom v9 (final).stl
Final 3D print file for controller body, bottom component
Standard Tesselated Geometry - 923.13 kB - 08/01/2020 at 12:35
Download
3 Battery clamp v2 (final).stl
Battery clamp
Standard Tesselated Geometry - 22.93 kB - 08/01/2020 at 12:35
Download
4 Pushbutton Short v7 (final).stl
Shorter pushbutton for nearer the user's hand. See note for Tall pushbutton.
Standard Tesselated Geometry - 148.81 kB - 08/01/2020 at 12:36
Download
5 Pushbutton Tall v7 (final).stl
Taller pushbutton for further from the user's hand. The difference between short and long is small. Usually the buttons are printed as different colors.
Standard Tesselated Geometry - 147.25 kB - 08/01/2020 at 12:36
Download
View all 6 files
  • 1 × Adafruit 1391 Keyfob 2-Button RF Remote Control - 315MHz
  • 1 × Adafruit 1904 Micro-LiPo Charger
  • 1 × Adafruit 1903 PowerBoost 500 Basic - 5V USB Boost @ 500mA from 1.8V+
  • 1 × Adafruit 1131 JST-PH Battery extension cable 500mm
  • 1 × Digi-Key 1832-1053-ND Lithium ion polymer battery   3.7V, 1AH
View all 13 components
  • Very successful design
    Andrew Mitz • 07/24/2024 at 11:14 • 0 comments
    Since the start of this project I have assembled 5 of these wireless switches. The latest version is rugged and reliable. The range of operation is only about 4 to 6 feet, but that works well for my application. As the battery runs down, the range reduces.
    I use 500 mAh batteries, but the controller will fit 1000 mAh batteries with no problem. I purchase fresh batteries every 4 years or so, but I actually do not know how long a battery will last.
    Assembly is somewhat tedious. The detailed instructions are very helpful.
  • Using heat-set threads for mounting posts
    Andrew Mitz • 03/18/2024 at 17:03 • 0 comments
    One weakness of the existing design is that the mounting posts can break when being tapped, or the threads can be stripped during assembly.  The best way to protect the plastic mounting posts is to use heat-set thread inserts.  Note, this only works with thermoplastics. There is an expansion-type insert that can be used on other plastics.
    I use McMaster-Carr part 93365A230. Carefully drill out the 4-40 thread holes in the mounting posts with larger and larger drill bits until you reach 9/64". Try to hit this size exactly (that is, buy a 9/64" bit). If you use other heat-set threads, drill to the specifications of those threads. Make sure the bottom of the heat-set thread just fits into the top of the hole. With a soldering iron (with a very clean tip), poke the tip into the heat-set thread and hold until the plastic gets soft. With a little push from the iron, the thread will advance smoothly into the hole. Lift the soldering iron off when the insert is completely inside the post. Have a small flat screwdriver handy to keep the thread from lifting up while you lift the soldering iron. There are some good demos in the Internet, so you can see how it works.
  • Project complete
    Andrew Mitz • 08/01/2020 at 12:46 • 0 comments
    The project is complete. A tiny tweak to the lower body case lip helps the case fit together without endangering any of the alignment posts. The USB charger board is held in place by the rear pins and the adjacent wall. The front pins (nearest the micro USB connector) are not used. Final STL files have been uploaded to print your own case.
  • Project files updated
    Andrew Mitz • 07/10/2020 at 22:26 • 0 comments
    Bill of materials file deleted and replaced by listing of all components. Draft step-by-step file replace by full set of instructions.
  • Capacitor to assure the controller triggers the receiver
    Andrew Mitz • 07/05/2020 at 19:58 • 0 comments
    I found two controllers that did not properly trigger the receiver. I saw a similar problem with a non-rechargeable controller I built earlier (see photo). The keyfob board is designed to work with coin cells. When you use a separate power source it lacks a low impedance RF pathway across the battery terminals. To solve this, I added a 1.0 uF ceramic capacitor across the keyfob battery terminals. The picture shows a capacitor with a 5.6 ohm resistor. You don't need the resistor. (The resistor was needed in that earlier design because I ran it on 6 volts, which was too high.) The capacitor solves the problem in the new controller. Some controllers will operate without the capacitor, but why take chances? The instructions have been updated to include the capacitor.
  • Draft assembly and BOM files have been posted
    Andrew Mitz • 07/04/2020 at 02:02 • 0 comments
    Files now have preliminary assembly instructions and bill of materials.
    Basic operation.
    In the chrg position, the controller is off and can be charged using a standard cell phone charger and a micro-USB cable. The charger LEDs will go from red to green when the battery is fully charged. In ON position, the battery is in use. The LEDs from the PowerBoost board should be visible: green when ON, but turns to red when the battery is low. The keyfob LED should light red when a button is pressed.
    The intended receiver is an Adafruit
    1096      Simple RF M4 Receiver - 315MHz Momentary Type
    It is built into my Raspberry Pi PlayVideo system
    https://wordpress.com/page/arm22q13.wordpress.com/3369
  • 3D printer
    Andrew Mitz • 07/03/2020 at 22:09 • 0 comments
    The 3D printer used for all the prototypes and production adaptive switches is the Flashforge Dreamer NX. Because the project was to aid disabilities, the use of the printer and materials were donated by two wonderful supporters of this project.
View all 7 project logs
  • 1
    Drill and tap battery hold-down
    Bottom half of case. Clear out battery hold-down holes with a #50 drill bit and pin vise. Carefully tap the hole with 2-56 tap.
  • 2
    Drill and tap mounting posts
    Top half of case. Very carefully drill the 7 thick round mounting posts using a #42 drill bit and pin vise. Go slowly and clear out waste a couple of times while drilling holes.
    Stop here. See Log file: "Using heat-set threads for mounting posts".  The heat-set threads work much better than tapping the plastic directly.  Optionally, you can continue with this step and tap the plastic directly. Step 7, below, shows heat-set inserts in three of the mounting posts.
    Tap these holes with a 4-40 tap. Tap the holes even more carefully than drilling. Keep the tap clean. Do not drive the tap too deep. The posts can snap off.
  • 3
    Cut off battery connector. Wire on new connector.
    [Warning: This step has risks. The battery is very powerful. Do not let the two battery leads touch each other.] See Step 11 for a picture. Cut the connector off the battery keeping 2 to 2.5 inches attached to the battery.  Do not cut the two wires at the same time with a metal tool. Cut each lead separately to avoid shorting them. Cut the JST-PH battery extension cable so that the female connector (the connector that has no exposed metal) has about 2 inches of wire on it. Save the other end of the extension cable, you will need it.  Strip (that is, remove the insulation and expose the wire inside) the wires on the female connector.
    Note that the RED wire of the battery must be connected to the RED wire of the connector. Decide if you will be using epoxy or heat shrink tubing to insulate the connections. For heat shrink tubing, strip one battery wire. Mount a piece of heat shrink tubing on that wire. Twist the battery wire to the matching color wire of the connector.  The wires should be twisted in-line with each other to allow the shrink tubing to fit over the connection. Solder wires together. Slide the heat shrink tubing over the soldered connection. Shrink the tubing. Now repeat for the other battery lead. With this method the two battery wires are not exposed at the same time. Now the battery has a cable with the correct connector. and the correct connections.
    The other way to insulate the soldered wires is with J-B KwikWeld epoxy. Connect the cable without heat shrink tubing. Me careful to keep the read and black exposed wires separated. Mix the epoxy and coat each connection. Be sure no wire is exposed. Do not handle wires for 20 minutes so the epoxy can set.
View all 25 instructions
Andrew Mitz wrote 07/17/2021 at 00:32 • point
3D printing was done on a  Flashforge Dreamer NX.
