Extended motor wiring
A project log for A Wheel
Another Satisfying Single Wheel Terrifying Hoverboard Conversion
masterofnullMasterOfNull 08/25/2022 at 00:180 Comments
I extended the sensor and motor winding harness.
The four most interesting signals got the solid colors for the sensor harness. Ground and Vcc then share the shield for those 4.  This should provided a modicum of shielding, not that this really needs it.
