This holds the toggle switches in place. I soldered little usb connectors to the switches so I can easily swap out whatever I want to power through the toggles.
Standard Tesselated Geometry -
152.82 kB -
09/14/2022 at 21:27
Simple shape to follow the arc of the internal frame of the backpack, with some holes in it to screw antennae through. Or whatever else fits in the holes. LEDs, bolts etc.
166.88 kB -
09/05/2022 at 17:57
laser cut from aluminum: braces terminal components and has hole specifically designed to accept helmet holder on backpack so terminal can be securely stored on the exterior of the pack.
printed with PLA: bottom part of cable enclosure for terminal female cables for solid positioning and allowing umbilical to securely plug in. Bottom also screws into terminal leg.
73.52 kB -
09/01/2022 at 14:36
