News Update 2023
08/04/2023 at 11:40 • 0 commentsI'm currently working on a LoRa version of this project with even lower power consumption:
around 400nA powered by 1.8V or
1 uA powered by a 1.5V battery
with all sensors shut down.
It comes with 3 separate voltage rails for EEPROM, sensors and the LoRa chip.
It features an external connector for connecting a sensor externally.
Current consumption of Canique Ambience with pulse counter
03/29/2023 at 17:44 • 0 commentsThe last 2 videos posted here are showing the current consumption of Canique Ambience (rev 1.2.0) with its pulse counter connected to the RPM signal of a fan.
The values measured (input voltage: 1.84V) are:
a) 1.05uA with the fan not spinning
b) 1.25uA with the fan spinning @ 900 rpm
Of course you could just as well connect the pulse counter to a rain gauge, a button (to count button presses) or some similar switch.
Ultra low power Pulse Counter
02/19/2023 at 10:44 • 0 commentsI'm implementing an additional pulse counter connector now. The reed connector will be a 4pin connector - 2 pins for a reed sensor, 2 pins for a pulse counter.
Canique Ambience will be able to count pulses, e.g.
- from a rain gauge or
- from gas/water/electricity meters or
- from a fan's tacho signal to calculate the RPM
with very low quiescent current.
Technically I will be pulling up the input pin via a 1Mohm resistor to 1.8 volt and current will only flow when a pulse is driving the input low. So if there is a 10ms pulse, then 1.8 µA will flow for 10ms.
The pulse counter itself will draw about 10nA.
If we assume that a pulse is coming in every second (1Hz), the average quiescent current that this circuit introduces would be 18nA + 10nA = 28nA. If pulses are coming in at a lower rate, then this figure will approach 10nA. If they come in at a higher rate, then average current will be above 28nA.
Another factor is the pulse duration. The higher the pulse duration, the higher the current consumption.
And don't forget the cable capacitance. A long cable will have a high capacitance. So even after releasing the pulse counter input, it can take a few ms for the capacitance of the cable to charge up - during that period current will flow to charge the cable capacitance.
Let's do a small calculation here. Assumption: Cable Capacitance = 1.6nF (80pF/meter, 20 meter cable)
1.6nF * 1.8V = 2.88 nanoCoulomb
2.88 nC = 2.88 nA * s = 2.88 nA for a 1 second period => we have to provide a current of 2.88 nA for 1 second to fully charge the cable capacitance
If the pulse rate is 1Hz, then we'd have an additional 2.88 nA of consumption due to the cable capacitance.
Next thing to consider is a debouncing circuit. The 1M pullup resistor will form an RC filter with a small capacitor (~1nF) so as to not count any bouncing in the switch. The reed sensor input also has an RC filter.
Until now I've written about driving the input low during a pulse. Is the opposite possible too? Driving the input high? If Canique Ambience is configured for that kind of operation (means: no pullup resistor), then yes.
An external device, sharing the same ground, can send pulses with up to 5V. The quiescent current of the pulse counter in Canique Ambience will be 10nA with no additional current since there is no pullup resistor active.
What are the differences between the reed sensor and the pulse counter?
Reed Sensor Pulse Counter Supported Drive Low Period Long (can be hours or days) Short (ms) Transmission Immediately Time based Power Consumption 240nA only while switch closed driving low: 1.8 µA during pulse +
10nA permanent
driving high: 10nAMax Frequency a few Hz a couple of Hundred Hz -
Roadmap 2023 and current state
02/15/2023 at 19:50 • 0 commentsCurrently this platform is also available with an external 4 or 5 pin header (100kHz I2C) to connect external sensors (up to 2m cable) to it. As of now it only has support for an external temperature/humidity sensor board.
In the course of the year it will support external ambient light measurements (in LUX).
Experiments with LoRa are also planned for 2023, especially with spreading factor SF5. The goal is to communicate via LoRa without affecting battery lifetime. This is like trying to take a shower without getting wet, but this won't keep me from trying it.
Roadmap?
08/28/2022 at 18:02 • 0 commentsAn ambient light sensor is on the roadmap for 2022. It will be part of the Canique Ambience sensor.
A 3D case is planned - ETA unknown yet
Could power consumption be reduced even further?
08/28/2022 at 17:58 • 0 commentsYes.
- Upgrade MCU: Cortex M4 instead of Cortex M0+. This increases cost, though.
- 2 batteries instead of 1. This decreases cost, increases size and decreases power consumption. It's a tradeoff.
- Delta transmission: Only transmit when delta between last transmitted and current transmitted datapoint is above a certain threshold.
