ACK ACK!
A project log for SPI4C
It's not SPI, I2C or I3C, it's another protocol with full duplex self-clocked links with 2×2 wires that is rich and easy to implement.
yann-guidon-ygdesYann Guidon / YGDES • 08/26/2022 at 22:01•0 Comments
More fun with CircuitJS:
I made a loopback to ACK the ACK. This gives a rough estimate of the latency and throughput. Note that I use 2 different clocks: 7KHz and 10KHz to test clocking issues. I can't see much though with this system and a more elaborate simulator becomes necessary. I wish I could hook/link custom scripts to add custom probes and features :-D But at least I could test the inter-wire jitter.
What is interesting is that ... This circuit makes no sense !
It's stupid to ACK an ACK, as it creates this "larsen" situation, self-oscillating... Here it helps create the throughput test.
What makes sense is to ACK data data
  1. when there is no data to send (but I have no PISO-SIPO yet) or
  2.  when the activity timer expires.
This is not wired yet.
