1Construct your board
Construct your own board according to the circuit:
2Get the ZIP archive and copy the files to MMC/SD card
- Go to the releases page of Machikania Phyllosoma in github.com, and download ZIP archive of latest version.
- Copy the files in ZIP archive to an MMC/SD card.
- Insert the card to connector of your board
3Install the MachiKania type P firmware
Drag & drop the "phyllosoma.uf2" in ZIP archive to RPI-RP2 drive of Raspbery Pi PIco
4Configure the INI file (optional)
Edit the MACHIKAP.INI file for configuring several settings.
