Serial OutPut of the project
A project log for Station_07
This is where i try to integrate everything in one project just for fun.
rfilesRfiles 08/28/2022 at 20:060 Comments
This Appears messy because of wrong font. Must be a fixed lenght.
Aug 28 2022 16:57:561
Station_07 Loader of 18 Modules:
Primary I2C Scan
 Got = 23  38  39  70
Primary I2C Scan Done
TCA I2C Scan
 Port 0 Got = 00 20 48
 Port 1 Got = 5A
 Port 2 Got = 10 29 68 76
 Port 3 Got = 23 38 39
 Port 4 Got =
 Port 5 Got =
 Port 6 Got = 00 40 5A 60 76
 Port 7 Got = 29
TCA I2C Scan Done
 00: SCN S[  23] D[158] OK
 01: RAM S[ 181] D[  1] OK
 02: SI7 S[ 182] D[ 53] OK
 03: BME S[ 235] D[123] OK
 04: ADS S[ 358] D[  0] OK
 05: MCP S[ 358] D[ 10] OK
 06: CCS S[ 368] D[204] OK
 07: MIC S[ 572] D[  0] OK
 08: SI1 S[ 572] D[ 52] OK
E (626) gpio: gpio_set_level(226): GPIO output gpio_num error
E (636) gpio: gpio_set_level(226): GPIO output gpio_num error
 09: VL5 S[ 624] D[ 72] OK
 10: TCS S[ 696] D[620] OK
 11: MLX S[1316] D[  1] OK
 12: BH1 S[1317] D[ 20] OK
 13: MPU S[1337] D[639] OK
 14: VE0 S[1976] D[  4] OK
 15: BMP S[1980] D[108] OK
 16: VL0 S[2088] D[2001] OK
 17: WS2 S[4089] D[  1] OK
Load Done
RAM: Total 0528 regs of 0248 bytes each.
Starting Timed Tasks
NOC: 000017   TOC: 000046   TIM: 01:00:49
BME: T[29.43] P[1005.826] H[45.10]
BMP: T[30.22] P[1005.495]
SI7: T[29.46] H[43.67]
CCS: eCO2[ 428] VOL[   4]
ADS: 1[  131] 2[ 1348] 3[   71] 4[17477](3.29V)
MIC: Carb Mono[3.19]  Diox Nitr[0.15]  Amonio[0.18] Propano[74.27]
MIC: Butano[70.54] Metano[194.24] Hidrog[0.45] Etanol[1.07]
MCP: IN(A)[###-##-#] OUT(B)[--------] Int[--------](0)(0)
BH1: Lux[41.67]
SI1: VIS[  261] IR[  261] UV[    0] PROX[  255]
TCS1: R[ 3467] G[ 3443] B[ 3588] C[ 7978] IR[ 1260]
TCS2: C_R[ 2207] C_G[ 2183] C_B[ 2328] R_C[ 6718] LUX[48.95]
TCS3: CR[0.16] AGX[   60] ATMS[  153] CPL[29.61]
TCS4: MAX_LUX[737.69] K[5409.89]
VE5: UVA[0.00] UVB[0.00] UVI[0.00]
VE0: UVI[0]
VL5: Distance [1739] mm
MLX: Amb[26.93] Obj[25.91]
MPU: Ax[0.00] Ay[0.00] Az[1.01] - Gx[0.01] Gy[-0.05] Gz[0.02]
MPU: Mx[30.29] My[110.58] Mz[229.36] SumG[1.01] T[36.58'C]
MPU: ANx[0.01] ANy[0.05] ANz[90.00] Pitch[-0.01] Roll[0.03] M[0]
Rich text editor
