Modules Used In This Project:
| HardWare | What I get |
| BME280 | Temperature, Pressure, Humidty |
| ADS1115 | 4 channel 15 bit ADC. Channel 4 connected to 3.3V |
| BH1750 | Light Intensity |
| BMP280 | Temperature, Pressure |
| CCS811 | Equivalent CO2, Amount of Volatile Gases |
| MCP23017 | 16 pin Input/Output Expander |
| VL53L1 | Laser Distance Sensor up to 4 meters |
| VEML6070 | UV intensity |
| 23LC1024 | 128kB External SPI RAM. Store Values. Pointless for now |
| WS2812B | 3 modules full RGB configurable LEDS |
| MICS6814 | 3 Gases Sensor. Uses 3 channels of ADS1115. Measures 8 Gases |
| MPU9250 | 9 Axis Montion Sensor. Accelerometer, Gyroscope, Magnetometer (3 axis each). Also chip temperature |
| SI1145 | Light and proximity sensor. Infrared, UltraViolet, Visible, Proximity (With white LED) |
| VEML6075 | Ultraviolet Sensor. UVa, UVb, UV intensity |
| SI7021 | Temperature, Humidity |
| TCS34725 | Light Sensor. Red, Green, Blue, Clear, IR, (LUX, K, CPL calculated) |
| TCA9548A | I2C Switch and level translator for all I2C devices |
| MLX90614 | Infrared Temperature Sensor. Object Temperature, Ambient Temperature |
SoftWare | What I Get |
| WiFi | WiFi |
| INFLUX | Direct Connection to Database. DOESNT WORK |
| MQTT | Send Data to Nodered in raspberry pi 3B+ |
| OTA | Auto check for Update in raspberry pi server, webpage server for update |
| I2C Scanner | Scans TCA9548 for devices and lists in Serial Port |
