This Appears messy because of wrong font. Must be a fixed lenght.
Aug 28 2022 16:57:561
Station_07 Loader of 18 Modules:
Primary I2C Scan
Got = 23 38 39 70
Primary I2C Scan Done
TCA I2C Scan
Port 0 Got = 00 20 48
Port 1 Got = 5A
Port 2 Got = 10 29 68 76
Port 3 Got = 23 38 39
Port 4 Got =
Port 5 Got =
Port 6 Got = 00 40 5A 60 76
Port 7 Got = 29
TCA I2C Scan Done
00: SCN S[ 23] D[158] OK
01: RAM S[ 181] D[ 1] OK
02: SI7 S[ 182] D[ 53] OK
03: BME S[ 235] D[123] OK
04: ADS S[ 358] D[ 0] OK
05: MCP S[ 358] D[ 10] OK
06: CCS S[ 368] D[204] OK
07: MIC S[ 572] D[ 0] OK
08: SI1 S[ 572] D[ 52] OK
E (626) gpio: gpio_set_level(226): GPIO output gpio_num error
E (636) gpio: gpio_set_level(226): GPIO output gpio_num error
09: VL5 S[ 624] D[ 72] OK
10: TCS S[ 696] D[620] OK
11: MLX S[1316] D[ 1] OK
12: BH1 S[1317] D[ 20] OK
13: MPU S[1337] D[639] OK
14: VE0 S[1976] D[ 4] OK
15: BMP S[1980] D[108] OK
16: VL0 S[2088] D[2001] OK
17: WS2 S[4089] D[ 1] OK
Load Done
RAM: Total 0528 regs of 0248 bytes each.
Starting Timed Tasks
NOC: 000017 TOC: 000046 TIM: 01:00:49
BME: T[29.43] P[1005.826] H[45.10]
BMP: T[30.22] P[1005.495]
SI7: T[29.46] H[43.67]
CCS: eCO2[ 428] VOL[ 4]
ADS: 1[ 131] 2[ 1348] 3[ 71] 4[17477](3.29V)
MIC: Carb Mono[3.19] Diox Nitr[0.15] Amonio[0.18] Propano[74.27]
MIC: Butano[70.54] Metano[194.24] Hidrog[0.45] Etanol[1.07]
MCP: IN(A)[###-##-#] OUT(B)[--------] Int[--------](0)(0)
BH1: Lux[41.67]
SI1: VIS[ 261] IR[ 261] UV[ 0] PROX[ 255]
TCS1: R[ 3467] G[ 3443] B[ 3588] C[ 7978] IR[ 1260]
TCS2: C_R[ 2207] C_G[ 2183] C_B[ 2328] R_C[ 6718] LUX[48.95]
TCS3: CR[0.16] AGX[ 60] ATMS[ 153] CPL[29.61]
TCS4: MAX_LUX[737.69] K[5409.89]
VE5: UVA[0.00] UVB[0.00] UVI[0.00]
VE0: UVI[0]
VL5: Distance [1739] mm
MLX: Amb[26.93] Obj[25.91]
MPU: Ax[0.00] Ay[0.00] Az[1.01] - Gx[0.01] Gy[-0.05] Gz[0.02]
MPU: Mx[30.29] My[110.58] Mz[229.36] SumG[1.01] T[36.58'C]
MPU: ANx[0.01] ANy[0.05] ANz[90.00] Pitch[-0.01] Roll[0.03] M[0]
