Toilet Water Optimizer
It uses gray water and leads it to the flash tank to save purified water to pump into the toilet bowl.
0 followers
The aim of This project is to slightly purify water coming from washed hands (gray water) with filtration to a temporary tank and save that water and reuse it by hydrological pumping (without electricity) to the flash tank if there is a need.
If there is no space in the flash tank the temporary tank saves the water until there is any space.
If the temporary tank is full gray water goes to the sewerage system.
If there is no gray water available by a floating handle valve the flash tank uses the purified urban water.
stp868650 wrote 03/24/2023 at 08:32 point
Quiet Flush Toilets  are specially introduced to eliminate the issues with loud flushing systems. With countless toilet brands available, it is one tough task to find the ideal quiet flushing toilet for your bathroom.
