I posted a video that expalins the crop water stress sensor
10/15/2022 at 17:22 • 0 commentsCheck out the short video that explains the crop water stress sensor in the project!
Future improvements
10/15/2022 at 16:25 • 0 commentsI added a future improvements section to the documentation and I'll post some updates whenever some of this works.
How to set up the sensor outdoors?
10/15/2022 at 16:14 • 0 commentsMost projects don't cover the part where the sensor is actually placed outdoors. I experimented with sunshade stands to position the sensor outdoors in the field.
I added the solar panel assembly!
10/15/2022 at 15:56 • 0 commentsI added a quick assembly guide to the solar panel support assembly and a few thoughts to this.
Camera assembly documentation is ready!
10/15/2022 at 15:42 • 0 commentsEven if it got a bit short, I finished the assembly of the thermal camera sensor.
Sensor box assembly documentation is ready!
10/15/2022 at 15:30 • 0 commentsI just finished the documentation for the sensor box assembly :)
Started writing the instructions
09/03/2022 at 10:38 • 0 commentsI just started writing the instructions, I'll complete them during the coming week.
Updated and published all files on github.com
09/02/2022 at 13:55 • 0 commentsThe .stl files as well as the files for the laser cutter and the code are available on github.com now.
Parts list updated!
09/02/2022 at 11:25 • 0 commentsI just updated the parts list. I'll double check later again if something is still missing.
Start writing the article
09/01/2022 at 15:37 • 0 commentsNow that the sensor has worked more or less bug and error free in the field, I can start writing the article.
Florian Ellsäßer
