To enable the Warmwater circulation a simple Sonoff Switch is used.
This Wifi Switches can be programmed with Arduino IDE very simply
You may find this cheap on ebay, aliexpress, Amazon
This Hardware is ideal fo a small and reliable Switch to control our currently 24/7 running warmwater circulation pump
Ulrich
