The itsy bitsy spider fell down the testing tree
A project log for XANDR the XTINGUISHER
A modular robot spider designed to fight fires and do preventative forestry maintenance.
andrew-bensonAndrew Benson 09/09/2022 at 08:200 Comments
One of the features of the current iteration of XANDR is a quadcopter that can take off from the back of the spider and carry a hook into a tree. A small magnet allows the quadcopter to detach from the hook, and the larger spider can winch itself up the tree for branch trimming. During the first test of the system the quadcopter lost control, and took a hard dive into some nearby cement. It seems like the FPV camera was broken in the fall - hopefully the quad can be repaired without too many new parts, and the next test will be done on a tree with softer surroundings (this tree was chosen due to proximity to the shop, and thus ladders.
