1Step 1
(I made a build video - however, it's been waiting to be edited for...some time.... At least it's in the works now!)
Preface
The main difficulty in the construction is actually just printing the parts and finding the right components. In the spreadsheet all parts are listed, with source of supply; many parts you will also be able to replace with others. For some parts, however, the dimensions must fit exactly, such as the speakers and the Noctua fan. Otherwise, the case would have to be adapted.
The largest parts are the four housing parts. Together with the "skeleton" parts inside, they form the basic framework of the deck. Both the "skeleton" and the individual modules can be customized depending on the hardware used. This requires some experience with CAD software though.
Chris
