Background
Decades ago, my employer sent me to training courses. There were some psychology questionnaires and this got me interested in psychology such that in recent years I've taken MOOCs in subjects such as Behavioural Economics.
One of the questionnaires I found during that period was for gauging optimism. Unfortunately I did not note where I found it. I coded it up as a C program for Turbo-C to be run on PCs (that's how long ago it was). Recently I came across the code and wondered if I could rewrite it in HTML+Javascript. So this quick project is a bash and Javascript refresher.
Format of situations and responses
The questionnaire contains 48 situations for which one of two responses must be selected. The format I'm starting from, slightly modified from the C data initialisations, is:
s The project you are in charge of is a great success 1 I kept a close watch over everyone's work 0 Everyone devoted a lot of time and energy to it
The first column of the situation indicates the trait it pertains to. The other traits are m and v. These mean respectively personalisation (is it me?), permanence/continuation (will it always be so?), and pervasiveness (is it always the case?). There are also inverse situations, marked by S, M and V respectively. An example of an inverse situation is:
S You get lost driving to a friend's house 1 I missed a turn 0 My friend gave me bad directions
The first column of the answers indicates whether that answer will contribute to the score for that trait, 1 for true.
6 traits and 8 situations each gives 48 items. Thus the maximum score for each of the 6 traits is 8.
HTML generation script
I considered the usual suspects for scripting, bash, Ruby, Python and Perl and settled on bash. It's very much within bash's capabilities.
The HTML code for each situation is straightforward, a situation followed by a radio button for each answer. For example:
<p id="s1" class="init">1. The project you are in charge of is a great success</p>
<p class="tab"><input type="radio" name="a1" value="s">I kept a close watch over everyone's work</p>
<p class="tab"><input type="radio" name="a1" value="">Everyone devoted a lot of time and energy to it</p>
The value attribute is used when tallying the counts from the DOM. For the answers the class attribute is used to indent using CSS. For the situation the class attribute is to highlight unanswered situations, the other state being "flagged". The id attribute is used to find each situation using GetElementById later. The answers are found using GetElementsByName as ids have to be unique. (Note, plural GetElements...)
It's easy to loop through the input file consuming 48 situations and 96 answers, generating the HTML. Notice the use of the range operator in the for loop. I make no apology for hardcoding 48 as the script is specific to this project.
For calculating the results and presenting them, I used a Javascript function that's tied to a button. It calls auxiliary functions for repeated code. For me it was a useful refresher in Javascript. My starting point is Javascript is modelled after C, so many C constructs exist in Javascript too, for example, increment, assignment, short circuit boolean, and ternary operators.
For string output, while you can concatenate strings and integers to get a string, Javascript has template literals which are useful for interpolating values into strings. For example:
s = `Across the board you are ${acrosstheboard(G_B)}`
The part inside ${} is executed as Javascript code and will result in the function call: acrosstheboard(G_B).
This feature requires a modern browser so it's not supported in Internet Explorer, but who cares about that, even Microsoft has EOLed it.
Position of Javascript code
I checked the Internet for advice on whether to put the Javascript code at the top of the file, in the head tag, or further down, in the body tag. I was convinced by the argument that putting the Javascript at the end would allow the web browser to render the initial HTML before reading in the code. There are no dependencies in the HTML on the code as it's only executed on button press, long after the browser has digested the HTML.
Code checking
I ran the bash script through shellcheck which flags problematic shell code. It noted that some features were not in POSIX sh and bash-specific so the header line was changed. Also note that the last here document in the script must turn off interpolation because of constructs like the backtick. Interpolation is needed in the middle here documents.
Tidy made one spurious complaint about the generated HTML.
Debugging
The Javascript console of the browser was useful for finding errors. As usual these include syntax errors, misspelt variable names, similar to other languages.
Using the HTML file
It is self-contained and can be run in any modern browser, you just need to point the location bar to the file. For example on my system, the URL is:
file:///tmp/optim.html
The third / is actually the root of the Linux filesystem.
Sample results
You are very optimistic about the permanence of bad events You are very optimistic about the continuation of good events You are moderately optimistic about the pervasiveness of bad events You are moderately optimistic about the pervasiveness of good events You are moderately hopeful You are average about the personalisation of bad events You are average about the personalisation of good events Across the board you are very optimistic Raw results: PmB 1 PmG 7 PvB 2 PvG 6 HoB 3 PsB 4 PsG 5 TotB 7 TotG 18 G - B 11
I am not sure if it's a good characterisation of myself, I could have gone either way on some questions. So I would take results it gives you with a grain of salt, just as a starting point for reflection.
Ken Yap
