New casing and more
09/30/2022 at 01:55 • 0 commentsAfter several iterations, I decided that I would need to 3-d print a new case, so that's what I did, along with a few sacrifices to ensure that the watch is smaller than before. For example, I decided to make the GPS module removable and removed the entire charger board inside so you can use it externally.
Comparison
09/11/2022 at 09:35 • 0 commentsComparing my watch to the Casio watch, and looking at them both, I can see that my watch is a bit larger than the Casio watch, but again, it can still do more.
Will it wear?
09/11/2022 at 09:32 • 0 commentsTest fit, just to see if it is wearable like a watch, and despite all the crammed components, its pretty lightweight.
Second attempt
09/11/2022 at 09:30 • 0 commentsBy 8/25/2022, I have decided to fill in the spaces, until they are closely packed together.
First time
09/11/2022 at 09:27 • 0 commentsMy first iteration of a compact watch.
