Power-on test
A project log for Repurposing an Accom Axial Control Panel
Turning an obsolete video editor console into a mothership-sized keyboard + trackball + stream deck
noughtnautnoughtnaut 09/12/2022 at 08:180 Comments
# 2022-08-24 Power-on test
Internal power connection
As mentioned, power was orginally delivered through a 6-pin XLR socket on the rear, internally wired to a Molex connector (which does not follow the Molex standard).
XLR-6pinMolex pin*Cable colour
Signal
3
1
Red5V - for driving the logic, LEDs, and VFD
4 + 1
2
BlackGND
2
3
White?? (not yet traced)
6
4
Yellow12V ?? - for driving the incandescent bulbs (in the majority of the lighted keys)
5 + shield
n/c
A power-on test was inconclusive. I had wired up a pc power supply with GND, 5V and 12V to three of the four connectors on the main board's Molex socket (sans yellow), but got no life signs (no beeps, no lights, no text in the VFD). I did not check for signals on the RS422 port.
Possible explanations:
Update: I had indeed wired it up incorrectly. I'm going to blame the colouring; R/Y is flipped compared to common pc usage.
