Test_Board.ino.rpipico.uf2The binary.uf2 - 132.50 kB - 10/08/2022 at 11:18 |
Test_Board.inoSimple firmware for the Pico to allow, via USB-Serial, testing all features of the board.x-arduino - 6.85 kB - 10/08/2022 at 11:18 |
Raspberry Pi Pico CNC Controller-B_Cu v0.3.pdfThe mask for etching the bottom copper layer.Adobe Portable Document Format - 45.84 kB - 10/08/2022 at 08:05 |
Raspberry Pi Pico CNC Shield v0.3.zipFirst published version of the KiCad design for "Raspberry Pi Pico CNC Shield SSB"Zip Archive - 84.07 kB - 10/08/2022 at 06:19 |
legalcode.txtAll my contribution to this project - on hackaday.io - is published under the "Attribution 4.0 International (CC BY 4.0)" license.plain - 18.22 kB - 09/29/2022 at 09:04 |
PCB v0.1 good and bad together.jpgThe milled text ist readable, that's most important.At the end of the milling, the calculated Z-zero was higher as in reality and half of the track of one driver was not milled :-( JPEG Image - 128.48 kB - 09/14/2022 at 19:50 |
PCB v0.1 awesome.jpgI was impressed about the result. Created with a "cheap" CNC router ... by an hobbyist ...JPEG Image - 77.84 kB - 09/14/2022 at 19:47 |
