PsuedoPancake Headset Template v2 Opened.stl
Standard Tesselated Geometry -
8.48 MB -
02/27/2024 at 21:20
Download
PsuedoPancake Headset Template v2 v2.f3d
fusion -
1.55 MB -
02/27/2024 at 21:20
Download
PsuedoPancakev2b.obj
PsuedoPancakev2b, fixed lens to display distance
obj -
120.27 kB -
10/27/2023 at 14:41
Download
Boson Print.obj
Main v2 print file with IPD system, lens holder, etc, small fix needed for display to eye distance (literal penny thickness addition needed)
obj -
453.83 kB -
10/26/2023 at 22:32
Download
Boson Skeleton.zip
A file showing the parts generally together
x-zip-compressed -
129.12 kB -
10/26/2023 at 22:32
Download
PsuedoPancakes v2.svg
The lens you want to cut, remember use 2 60mm and 2 70mm! Also ensure you flip one 60mm and 70mm so all have the smooth end facing the user's eye
svg+xml -
2.74 kB -
10/26/2023 at 22:32
Preview
VGLensHolderv1.stl
Version one of the lens holder (check for errors!)
68.25 kB -
04/19/2023 at 00:15
Download
VGLens3DModelv1.stl
Version one of the lens, represented as a 3D model (check for errors!)
14.93 kB -
04/19/2023 at 00:15
Download
Vector Gear DXF File For Cutting.dxf
VG Lens 1.0 DXF file for cutting!
AutoCAD DXF -
6.77 kB -
04/19/2023 at 00:07
Download
