Teensy drum machine
Teensy + Faust drum machine
0 followers
A drum machine based on a Faust code running on a teensy with the following features:
- Ideally 8 voices (probably more like 5)
- Individual triggers
- Mix output
- Individual output per voice which removes voice from mix when plugged in.
- Selectable “kit” parameter to select different voice presets. CV controllable.
- All knobs CV controllable
- Line output
- Eurorack output
- DC power
- Eurorack power
Notes
codec IC:
  • ​Running multiple Faust drum simulations on Teensy
    Lee Sampson09/19/2022 at 09:57 0 comments
    I need to test how complex I can make the Faust code and it still run smoothly on the Teensy, taking into consideration all the other processing that it will need to do.
  • Teensy 8 channel audio board
    Lee Sampson09/17/2022 at 14:16 0 comments
    First task is to design an 8 channel audio out board based on the Cirius CS42448.
    Schematic
    Data sheet
    don’t need any inputs.
    Need to look at output scaling for Eurorack and line level.
    Think initially I will make a pcb that a teensy can connect to directly, but eventually I may add the circuitry directly to the drum machine pcb.
    Realising that I need to build this for Teensy 4.0 / 4.1 as other models are not available. This means less Ain pins but will have to do the multiplexing idea.
View all 2 project logs
