Running multiple Faust drum simulations on Teensy
09/19/2022 at 09:57 • 0 commentsI need to test how complex I can make the Faust code and it still run smoothly on the Teensy, taking into consideration all the other processing that it will need to do.
Teensy 8 channel audio board
09/17/2022 at 14:16 • 0 commentsFirst task is to design an 8 channel audio out board based on the Cirius CS42448.
don’t need any inputs.
Need to look at output scaling for Eurorack and line level.
Think initially I will make a pcb that a teensy can connect to directly, but eventually I may add the circuitry directly to the drum machine pcb.
Realising that I need to build this for Teensy 4.0 / 4.1 as other models are not available. This means less Ain pins but will have to do the multiplexing idea.
