The Keyboard is stored in front of the display for transport. Two latches can be pressed down on top and the keyboard can be removed from the package.
JPEG Image -
9.11 MB -
09/20/2022 at 18:54
Preview
The display is spring-loaded and held down by a pin in the bottom.
JPEG Image -
10.13 MB -
09/20/2022 at 18:53
Preview
On press of the "TILT" button, and the pin is mechanically released, so the display can be tilted to the desired angle.
JPEG Image -
9.74 MB -
09/20/2022 at 18:53
Preview
On the backside I made one big cutout, which is used as an exhaust for the hot air.
JPEG Image -
9.36 MB -
09/20/2022 at 18:53
Preview
The back can be removed after undoing just 3 screws. 3 additional clips are located at the bottom.
JPEG Image -
10.49 MB -
09/20/2022 at 18:53
Preview
Most of the air intake is handled by the old 5.25'' bay slots, which is therefor covered by a dust filter.
JPEG Image -
9.38 MB -
09/20/2022 at 18:52
Preview
Once the back side is removed, the 3D printed part just slide in and out. Especially useful for the dust filter.
JPEG Image -
11.11 MB -
09/20/2022 at 18:53
Preview
The bottom part of the pump's cooler had to go, to make it fit onto the radiator.
JPEG Image -
8.11 MB -
09/20/2022 at 18:53
Preview
It is a pretty crammed setup and I wouldn't want to swap out a part, but it all fit in the end. Maybe I will go for a 360 mm radiator next time.
JPEG Image -
10.71 MB -
09/20/2022 at 18:53
Preview
The Fillport extension, so you are at least able to fill the loop and the display controls on top, in case you need to change some settings.
JPEG Image -
9.83 MB -
09/20/2022 at 18:52
Preview
This little 3D printed thing, helps the tube stay in shape.
JPEG Image -
10.31 MB -
09/20/2022 at 18:53
Preview
Here all the motherboards and GPUs IO is accessible. I also installed an additional 80 mm fan here to maintain some airflow over the mainbaord.
JPEG Image -
9.08 MB -
09/20/2022 at 18:53
Preview
A flat HDMi cable for the integrated display. The rest is accessible for external displays.
JPEG Image -
8.51 MB -
09/20/2022 at 18:53
Preview
For the complete setup, you are only missing the mouse (and headphones).
JPEG Image -
11.90 MB -
09/20/2022 at 18:54
Preview
The overall package is quite heavy, but the sturdy handle holds all of it without a problem.
JPEG Image -
10.38 MB -
09/20/2022 at 18:54
Preview
Same as the other picture, but without compression.
JPEG Image -
9.33 MB -
09/20/2022 at 18:53
Preview
Parts and pieces.zip
Here are some of the more useful parts in Fusion 360 and STL format. This is only the V1 and I barely even manged to complete it, but I am happy to help if you are doing something similar.
x-zip-compressed -
1.75 MB -
09/20/2022 at 19:39
Download
